as I said in the headline: sometimes movies start really quiet, I have to get volume up to 50 (I normally watch movies between 15 and 20). I have to go back for one minute so the movie reloads/re-buffers and then the sound gets normal again. I have it on several apps (Netflix, Prime Movies, also my local broadcast app), so it's definitely not related to any app.
Anyone else noticed this issue? Any ideas?
Thanks !
    • By crct
    • By starwoodtech
    • By denisuu
      Hi all,
      I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4.  I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
    • By Maria D
      How to change view from 16:9 in movies to fit full screen
      LG QLED B22
    • By Danilo Peixoto Ferreira
      I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
