Libin Posted November 5, 2017 Posted November 5, 2017 You tube and some other apps restart sometimes and shows a app will restart to free up memory Quote
0 George Hofmeister Posted November 5, 2017 Posted November 5, 2017 Yes it is a unwelcome 'feature' for which there does not seem to be a cure for. If it is not happening too often then I am afraid you will just have to put up with it. If it is happening regularly (like every couple of minutes) then try resetting the TV back to factory defaults and re-install your apps. Quote
Libin
