Turn off HDMI onscreen messages
By OliverRC
By hollean
By u84six
By Kane Murphy
By starwoodtech
Swaish
How can I switch off the very annoying onscreen messages which appear when any device that’s plugged in switches on or comes out of standby to record?
I don’t want to be informed about a HDMI input being available thank you!
