[pivotCE]Unlock your HP TouchPad 4G
By anna groove
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
