[pivotCE]Project Macaw updated, adds 280 character limit
By mahdi alborzi
I need to update this TV
Model : 55SJ850V-TA
Serial number : 707CGKWMJ215
ESN : LGTV20171=11001816919
VSN : 1F580793
Widevine: LGTV17CLGE002389488
By mahdialborzi
از درگاه وای فای بروزرسانی نمیشود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
لطفا کمکم کن ید
By Ian_AW
G'day,
Many apps will bring up an alphabetised layout of keys rather than the more conventional QWERTY keyboard.
Is there a way of overriding this so that a conventional QWERTY layout can be used?
Thanks.
By Kevin_Idaho
Our LG TV was just updated with the latest software - before when the TV was turned on it was set to the previous input (one of the HDMIs). Now it appears to be sent to the Home Dashboard and I have to manually change it to the desired HDMI input. Does anyone know how to fix this? Thanks!
By David J
Hi all,
My LG OLED55E7N just updated to firmware 06.00.25. I must have wronged the god of Google, because I fail to find any whatsnew. Anyone?
Thx
