By atcronin
By Will M
By Lesbo
- 0 replies
- 2,083 views
- 6,930 views
- 4 answers
- 4,370 views
- 2 answers
- 2,738 views
Vinod Gupta
We need to buy a large number of 4K Smart TVs. We only need to display our plain text events list published on our web server. No RF Tuner, no multiple ports, no multiple apps, no other advanced features needed.
We evaluated your LG 43UJ6300 Ultra HD Smart TV (2017 model). This TV has many more features than we need but yet missing a couple of crucial ones. We could not find anyway to automatically start web browser on start up and we could not disable its screensaver. How do we set & save these two kiosk settings?
