Hi all,
At some point previously, I've been browsing TV shows via the TV guide. I've scheduled a program to come on when it starts, but it seems I've set this to happen at the same time every week. The show I had scheduled has finished, and I cannot see where this is scheduled to cancel it.
Can anyone assist?
Thanks!
    • By JasonB
    • By northshields
    • By Peter_T
    • By wallyricks
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
