On 24/11/2017 at 10:00 AM, john morgan said:
How do i install android apps from google playstore on this tv. I keep getting file not supported message.
thanks
John
Hi John,
The reason you cannot install apps from the Play Store is that your television runs on LG's iteration of webOS which is nothing to do with Android.
