Guide slow to load
By northshields
By NickL
Br,
Nick
By Mandx
By Hasan Ghasabi-Oskoei
Can you help?
By Peter_T
- 0 replies
- 1,100 views
- 24 answers
- 32,410 views
- 0 replies
- 4,586 views
Questions about LG Web OS Smart TV and Dish TV Set Top Box
By AnonViewer,
- stb
- mychannels
- (and 2 more)
- 14 answers
- 11,939 views
Den C
The guide is slow to load. This is not the case with other TVs like Panasonic and Samsung, where the guide comes up instantly.
