TV Guide Empty on Startup
I have setup Free To Air (FTA) on my new LG 4k TV and it works great, except when you pull up the TV guide it's empty and it takes ages to populate, also, when it does populate there's only now and next listed. Is it possible to upload an 8 day EPG on an external USB? And failing that, is it possible to get the TV to store even the now or next so it's there when I open the TV guide?
Tom
On 26/11/2017 at 3:43 PM, Tom Thornbury said:
Tom
Hi Tom,
Going purely by your name I'm going to take a guess at you are in the UK, if I am correct take a look at this post:
If you are in the UK then these might be of interest:
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
      SANTA CLARA, Calif., October 29, 2024 — Showcasing cutting-edge technological solutions,
      link hidden, please login to view, the North America Innovation Center of LG Electronics, announced the winners of the 2024 Startup Pitch Competition, co-sponsored by LG Chem. This year’s event, held during LG NOVA’s annual  in San Francisco, featured standout startups focused on Life Sciences, Open Innovation, HealthTech, AI, Smart Life and CleanTech, with three companies recognized for their potential to drive impactful change. Ten startups competed for cash prizes and recognition in front of a panel of industry experts, LG executives and investors. The 2024 winners are:
      First Place: . – mDETECT has developed highly-sensitive cancer blood tests using DNA sequencing, offering a universal approach to monitoring therapy response and detecting cancer progression. The company received the top prize of $15,000. Second Place:  – Glidance is revolutionizing independent mobility for people who are blind or have low vision with Glide, the first AI-powered intelligent guide, which enhances confidence, safety, and autonomy. Glidance was awarded $10,000. Innovation for Impact:  – Oncoustics is transforming low-cost point-of-care ultrasound devices into powerful diagnostic tools for early detection and monitoring of liver diseases using AI. Oncoustics received $10,000 for its selection as Innovation for Impact company. This award category was sponsored by LG Chem. In addition to cash prizes, participants will have the chance to explore further collaboration through LG NOVA’s , which seeks to support innovative startups through potential collaborations, partnership programs, marketing opportunities and other resources.
      “We’re excited to recognize startups that are truly pushing the boundary of what’s possible, developing technologies that have the potential to make an impact on people’s lives,” said Dr. Sokwoo Rhee, corporate executive vice president for innovation at LG Electronics and head of LG NOVA. “These companies are leading the way in critical fields like healthcare, cleantech, AI and life sciences and we look forward to exploring opportunities with them as they continue to advance their innovations. Together, we can shape a brighter tomorrow by driving meaningful change through collaboration.”
      The fourth annual LG NOVA InnoFest brought together industry leaders, investors and startups to explore emerging technologies in a collaborative environment. This year’s theme, “Lighting the Halo for Innovation,” emphasized the importance of co-creation in driving meaningful progress. The festival featured over 70 speakers, covering topics ranging from building successful ventures and the future of AI to innovative digital care models, energy management and more.
    • By Seppel
      i am in the process of purchasing several LG digital signage displays and need some more information before i place
      my order.
      I need a function like kiosk mode to start a website in full screen mode on device startup.
      The device would be a LG 43UH5N-E installed is webOS.
      Is this posswible with the onboard functionallity of webOS or do i need a 3rd Party App ore something?
      There is no need for a pagerefresh or such things, only display of es simple Website.
      thx for help me out.
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
