remote control disabled, most of function in setting menu gereyed out.by using smartify LGremote app
DB2EAA6D-5B50-4B87-A461-8694C67D96A2.thumb.jpeg.fe1e9f4dff3f52e1dd75c20eccfb3e50.jpegHello everyone  ,
TV model :55EG9200
webOS  2.2.1 -1338 ( beehive-biscayne )
My original remote control doesn’t work and only able to turn it on/off also initial setting greyed out account management gereyed out non of remote app on phone can be pair
I’m really disappointed
can you help me and get it touch,,,and the picture below shows my tv’s publis display setting is enable( ON )
After a day , I have been in my friend and I noticed he is using almost the same TV as me ! I downloaded smartify LG remote back ! I checked if this menu be On ( Enable ) as shown in the picture ( public display setting ) everything will be same as my TV .E55428A7-85C2-4B66-A7DA-66BC9B32A232.thumb.jpeg.00f9a3555bd99e038b7ac0035cc5872e.jpegthank you for supporting in advance
  • 1
TV model :55EG9200
Have a look at this video:
Towards the start of the video he mentions a couple of remote control/TV reset button combinations you can try.
    • By RJ Fischer
    • By Regis Wheeler
    • By JasonB
    • By u84six
    • By joepineapples90
      So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors).  So my question is, do any other LG remotes work with the G4?.
