Do anyone have OLED55C7V - 03.51.20 firmware file?
I am trying to downgrade my C7 using the LGDTVUPDATER method and it works very well but I need the 03.51.20 firmware info/file for EU.
The program has the AU (Australia) version but not EU. Does anyone have 03.51.20 firmware file or link for EU version? OLED55C7V
Or does anyone have access to
or and give me the link and REQ ID to the above firmware version?
I am currently on 03.60.09 but I am hating how much dimmer the HDR Game Mode is with this update.
A direct download link is going to be nigh on impossible as the file is apparently hosted on an Adobe server hidden by javascript and impenetrable file names.  For example:
<a adobe-down="down-csfile" adobe-file="Software_File(Version_04.70.10).zip" href="" onclick="javascript:return fncFileDown('20150500474577', 'KgBVKAOIxL52ctNKg34jiA', 'Software_File(Version_04.70.10).zip', 'GCSC', 'N', '', '')" title="Download a file" target="_blank" adobe-click="manuals" adobe-model="OLED55C7V">
However Softpedia seem to have links to the file:
  <span>Software_File(Version_04.70.10).zip</span>
Thank you for the reply George.
Yes it's definitely not easy getting a link to the file. i think you have to have access to the websites I mentioned.  The creator of LGDTVUPDATER has access to all of these old files and info, but I don't know how to get in touch with him.
I got a firmware version from LG Spain, which should work on all EU tv sets, but it still doesnt work. After reading a lot on forums, it seems all the 2017 OLED has a built in block that won't let you install a older firmware version.
Does anyone here have successfully downgraded a 2017 OLED tv?
    • By Lorenz
    • By SHawk
    • By Sqwazy
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
