By
JayDee
I have spent countless hours trying to figure out which remote is compatible with my 27 inch LG television. I can find the TV on LG's website (after intensively searching each time), but when I search the Magic Remotes for compatibility, I've had no luck in anything matching the two.
TV model is 27LQ625S-PU, purchased from Best Buy in America. I'm running 7.3.1-38 for webOS TV version. Trying to purchase one elsewhere online also seems to not have anything resembling my TV make/model.
I don't know what else to do in order to find a remote that works, and I don't want to spend the money trying ten remotes until finding one that does. Am I missing something through the site where I should be searching? Do all remotes work based on webOS version? I'd really love to upgrade this mostly useless remote. I don't use it much right now because I don't like typing through the on-screen keyboard and the remote that came with the TV isn't as easy to use as a universal (I think some of the buttons are in oddly located places). I tend to use external smart devices because the (dumb) remote/webOS don't seem to pair together very well.
I appreciate any help you guys are able to offer, and apologize if this seems like a foolish question.
Anas Abdulkareem
hello
i have issue ,
i have install app "lg tv plus" for ios ( Iphone 6 )
I connect my tv (lg 43uj651v) to same router with my phone
but the apps not find any tv to connecting
and idea ?
