- 1
Lip Sync Problem
By Venkata
Hello Team,
By informatiko
By PVD
By hollean
By AJO
- 5 answers
- 598 views
- 5 replies
- 3,586 views
- 895 views
- 2 replies
- 3,847 views
MAUICUDA
Great picture but how to fix lip sync problem, only on ABC network channels, coming from Spectrum Hawaii? Same cable box into my older Panasonic Plasma, using same HDMI cable: do NOT see lip sync problem. What am I missing, or what is different coming in on the cable that bothers the LG set but does not bother the Panasonic TV?
4 answers to this question
