Firmware downgrade.
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
By SailorMoon
- 8 replies
- 35,853 views
- 0 replies
- 16,655 views
- 0 replies
- 2,095 views
- 17 answers
- 23,777 views
WillyWonka
I just purchased a 49UJ7700 TV, and updated it to the latest firmware via flash drive (4.70.30). However, after do so, I lost the following apps:
Not exactly "lost," but they just disappeared from the LG Content Store.
I have seen the firmware downgrade instructions elsewhere in the forum, but unfortunately LG does not supply download links for previous firmware revisions.
Where can I download version 4.70.07?
Has anybody else had this problem?
4 answers to this question
