Favourite Lists does not show up
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By Lesbo
By Gregor Huc
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
- 0 replies
- 5,879 views
nimra
Hello please help.
I recently bought a LG 49UJ635V and updated it to the latest OS version 3.5. I am able to sort channels to Favourite Lists, but I am not able to access the favourite lists with my remote to select a channel from.
On my old LG TV it was "List" and left or right arrow, but with webOS this does not work. Am I too stupid??? 😪
Does anyone in the world has managed to see the favourite lists with webOS 3.5??? If yes, please give me a hint.👍
Armin
