I have a LG TV with WebOS 3.5.  I have used several remote apps like Anymote and LG TV Plus. But none of these apps can send text to any LG app. It doesn't work in Youtube search or email/password fields. Is there any remote that is able to do this?
    • By M FA
      How can I copy and paste text, for example from the URL bar in the browser???
      How come a very basic feature like this be missed?????????????????!!!!!!
      I started to hate this OS
      Bad decision to buy it instead of android TV.  LG is not putting any effort to catch up with the very basic features!!!!!
    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
    • By swattt
      Dobrý den,
      Při sledování Smart TV LG s android boxemTesla se mi často vypíná obraz (problikne) a v rohu se objeví HDR. Nevím si rady v TV to nejde zakázat tak už opravdu nevím?? Kabel?? Mohl by mi prosim někdo dát někdo poradit co s tím?? Děkuji.
