  • 5 years later...
    • By OhmorrowSouthWales
    • By Michael Hirons
      Can anyone advise me whether this tuner is "generic" or freesat? and i would like advise on using it with a Sky+HD satellite dish.. any advice/help appreciated as im cancelling sky contract soonĀ  Michael
    • By Tony Levy
      I have a brand new LG OLEDC8PLA model and have both an input for my aerial and for my Satellite however i cannot seem to find anyway to switch from watching via my aerial, which is Spanish DTV and then switching to my Satellite to watch UK TVĀ
      I live in Spain hence the two systems.Ā  When I press the home button on the remote the list is at the bottomĀ  and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menuĀ select Programme Tuning and switch the programme mode from Satellite to Antenna.
    • By leader6234
      Hey guys !!!
      I have a UHD UJ634vĀ  LG webos TvĀ  that lately an error message pops on the screen staying : Tv signal has been lost due to the satellite LNB short.Check LNB connection"
      This is really getting on my nerves because I can't get any signal even after resetting the TV or even updating to the lastĀ  software version.
      Here is the actual error message on the right top o the screenĀ
      Thanks in advance !!!
    • By Mahboobeh Nazouri
      How can I add yahsat to my satellite list webos lg tv????
