TV does not connect to internet and after seconds it shuts down
By Roy Brown
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By Lesbo
By JamesH
By SHawk
Jennifer Rosales
I have a Lg webos tv uf6450. Yesterday I was watching Netflix and all of a sudden the app displayed me the advise that there was no internet. So i go to settings to connect it again to the internet; I wasn't surprised since the tv has done it a couple of times. But this time it didn't want to connect. I tried everything: I disconnected the modem (even if the internet was working perfectly on my cellphone or any other device), I rewrote the password, I restart all the settings from the tv, I disconnected the Tv for a couple of hours, my brother even changed the password from the internet. And that is not the only problem. Sometimes, while I was trying to connect, the tv just freezed and then it shut itself down and even when I was trying to turn it back on, it didn't want to. Occasionally, the tv would not respond to the commands of the remote control. As I said before, I've tried everything, but if any of you know how to solve this problem I would be infinitely grateful. Please, help me!
