Cannot select the right langage on Keyboard
I have bought a Keyboard Rii Mini i8+ AZERTY (=>French) for my LG TV running on WebOS 3.5.
The problem is that by default the keyboard is detected as QWERTY (=> English).
I can change the langage to French by displaying the virtual keyboard on the screen. It will work for one text field, then it will go back to English.
I went to the keyboard langage options menu in the TV parameters : my idea was to remove English langage, or change the order of preference. Unfortunatelly,  both English and French langages are preselected, and appear in grey, so I cannot select/unselect them. Also, I didn't find a way to choose which is the prefered langage.
Any idea someone ?
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By Diaa237
      How can i do right click on my LG smart TV by my magic remote?
    • By joe zx
      I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
      I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
      Any advice, thanks.
    • By starwoodtech
    • By Peter Steinmeijer
      I can't connect  my LG ThinQ app to Google Home app.
      But my tv, the LG Web OS TV  UM7100PLB ( 2019 ), is in the LG ThinQ app. I even reinstalled it.
      Is my TV too old ?
