[pivotCE]Forums fix for webOS Nation, Communities fix forthcoming (hopefully)
If you have
and/or Communities for the TouchPad, you’ll notice webOS Nation forums aren’t working. The good news is, there’s a fix for it for Forums. The bad news is there’s no fix for it in Communities…yet.
forums_home-180x300.png?resize=180%2C300webOS Nation forum user, Fred Zyphal, and others jumped in to confirm and to test some solutions.
It turns out Forums just needs the entry for webOS Nation updated from http to https. So swipe away your old entry for it and add a new one with the “s” after http.
Communities seems to be more difficult and a fix is still in work. You can load Forums on your TouchPad if you want but it only shows in the phone emulator view.
If Communities can’t be saved it may be possible to format the Forums app to take up the whole screen on the TouchPad though. More to come on that.
#webOSforever
No related posts.
