After finally getting through downloading the user agreements, I was prompted to do an update on my LG Smart TV.  I monitored the update progress, which took hours. I don’t know exactly how many, but after two hours the update was at 32%. I let it run all night and it was finished by morning. Has anyone had this issue? Will all updates take this long? Thanks!
Its the same for me.  Ive worked on this for hours looking at videos and online info.  very frustrating.  Now its been downloading the software overnight and is only at 56%. My WiFi speed is fast, so Im at a loss here.  I have 90 days to return the tv and if I keep having problems its going back.  Theres a ton videos about how to fix issues on Youtube, which means there can be a lot of problems.  Also calling my cable company today to see if they have a solution.
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
