I am new to WebOS and trying to setup my environment. I followed the same steps mentioned here:
After completing these steps, I found four new applications installed in my system: webOS TV CLI, webOS TV IDE, Oracle VirtualBox, webOS TV Emulator v3.0.0. Now, when I am trying to run Emulator, nothing is happening. I am using macOS High Sierra.
Can someone please help me out in this? ☹️
3 answers to this question
56 minutes ago, skhulbe said:
I found a workaround for this:
Goto to the path where SDK is installed > Open "LG_webOS_TV_Emulator.vbox" with Virtualbox.
Can you connect to that VM?
I manually added the VM and was able to get it running, however i am unable to connect via any 'ares' commands or the IDE
Yes, I am able to connect to VM using 'ares' as well as using IDE.
The problem I am facing now is, I can only see TV's emulator, not Remote's.
    • By Rex G
    • By sudar shan
    • By NaveenKumar
    • By jcol5786
