Bought TV in China & moved, want to region switch but cannot
Hello
I bought my TV this year in China and I've moved to HK where I can access Netflix & Youtube etc etc, however, I'm unable to change the region settings on my TV as it only allows me to select China under the country list. Is there anyway that I can update the OS manually in order to region switch as the China apps are very limited..
Thankss
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By JamesH
    • By Luka Pantsulaia
    • By Tony Levy
