By
wallyricks
My PC setup is: Windows 10 Pro (with all latest updates) and a TP-Link Archer BE19000 (BE805) router. NOTHING has been changed on my router, TV (no updated or changed firmware) or any equipment moved around in the last 4 months.
bar1
Hi everyone,
I am new to Webos and to the forum...i am sure this question has been answered before but i can't find the answer.
Can i program the netflix button on the remote to launch a another app?
also my TV isn't connected to any live tv services....can i change webOS to automatically start an app when switched on?
Regards,Bar1
7 answers to this question
