Hello, I use Servio as home server media but there is a problem. On my LG TV with webos 2.0 subtitles from the movie does not play the characters correctly. There is a page code on the TV (Central European, Cyrillic, ...) but it does not correct the problem. For verification, we copied the movie and the subtitle on a USB stick and the playback is correct, no problem.  I use the DLNA network, this issue appears. The operating system is Windows 7 x 64.I guess that SO is guilty. Any ideas? Thank you. (also,i have web os 3.5 TV LG but no page code setting and same issue)
3 answers to this question
Оправи ли ти се проблема
Оправих го.
Отворих файла на компа и го запазих като смених на unicode 😜
2 hours ago, Kalin said:
Оправих го.
I fixed it.
I opened the comp file and saved it by changing to unicode
(via Google Translate)
    • By JasonB
    • By MURAD
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
    • By jcol5786
    • Solution For That Pollution
    • By Phil7108
      We recently subscribed to Paramount Plus to catch up on episodes we lost when our COX CONTOUR DVR died. Frequently when streaming an episode,the playback will suddenly freeze. If we try to go back, using the "undo" key, we can sometimes get the playback to resume, but it has rewound abp=out 10 minutes. After resuming playback, it will frequently freeze again. My wife is so frustrated, she wants to cancel Paramount. Any suggestions appreciated!
