By
atcronin
jvgama
Hey everyone, I think my TV is screwed up
After having some issues with the YouTube app on my LG 49UF6800, I read on LG’s support page that doing a factory reset should solve the problem. So I did that, the TV quickly rebooted and started showing a grey screen with three colored dots going in a circle, as if it was loading something. The thing is: this loading is endless. It’s been going for almost an hour, I’ve already tried unplugging it, but it goes right back to the grey loading screen. The only button that works on the remote is the power, as well as the mouse cursor.
Any ideas on how to fix this?
8 answers to this question
