LGWebOS Version 5.30.01
Dears,
I have an LG TV (LH600Y) with WebOS 5.30.01. I'd appreciate it if you tell me how can I upgrade tbe firmware to thw latest version because this version doesn't supports videos that open with flash player.
Bests,
6 answers to this question
You may check at LG website. If they do not offer a newer version, it is very likely that there is no new version. BTW, I don't believe that the upgrade will help you with the flash videos.
Expand
Thank you for your reply. I have another TV with WebOS 5.5.0 and this TV opens flash videos.
Expand
really? I thought flash was an issue. is that firmware version or webos version? I thought the latest was 3.5, that's interesting.
Expand
I have just checked that.
it is called Software Version,  isn't it the WebOS version?!!
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By Ali Zia
    • By Burkey
      hi all. new to this but really stumped!!! i live in ontario canada and have been using cogeco cable for internet and tv. it got way too expensive so i cancelled both and switched to bell 3.0 which is at least 3 times faster and we have no tv package, so we are just streaming everything for 1/3 the price!!!!!  i signed up for a couple of sports sites, tsn and sportsnet + so i can watch hockey playoffs and other sports.  tsn works just fine on the tv.  however, sportsnet + says that i have to have web os version 89 or higher.  i found my tv, which is a 2023 version, is only version 87!!! i chatted with tech support and they were no help.  anybody got any ideas as to what i can do for this???  no auto software updates for it and nothing on the lg app store.  quite confused how a 2023 model is not up to date, or sportsnet+ is that far ahead and not backward compatible>>>
      thanks to anybody that answers.
      dave
