ITS NOW 2018: Does the 2TB USB limitation still apply? even with NTFS and WebOS 3.5
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By Lesbo
By Gal Avraham
Apparently, some apps no longer run on webOS 3.5.
Is there a way to upgrade or reinstall firmware and webOS to 4 and later?
Maybe with a USB or so (i.e. offline)?
Gal
By Gregor Huc
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Wondering,
- smartshare
- usb
- (and 1 more)
- 1 answer
- 937 views
- 1 reply
- 3,001 views
- 1 answer
- 9,155 views
- 3 replies
- 19,162 views
