Channelgroup can not be deleted
By benwten
I set recordings or reminders from either search or TV guide.
Then when I look at the scheduler I see that they are listed.
The problem is that maybe later in the day, or on the following day, when I check the scheduler to see if my planned recordings are there, I either see some are missing or the whole lot have disappeared.
To be clear: I mean they disappear before the event happens.
This I have investigated after recordings failed to happen. I have not retuned or reassigned program channels etc or changed any settings or anything like that.
Why does this happen?
I swear this used to work when TV was new.
Is there a bug with my firmware version?
Fw version: 05.50.10
TV: 43uk6750pld
Hard drive: Maxtor onetouch III mini 80gb
Sometimes, for reasons we've yet to determine, the built-in first-party apps can disappear off an HP TouchPad. It's rare, but it happens, and for the average user it's annoying, frustrating, and confusing to have a basic app like the App Catalog or Calendar just up and disappear. Thankfully, HP has made it relatively easy to restore these apps, and you can do it all on your TouchPad, though some homebrew magic is required.
First things first, you'll need the excellent homebrew file browser
link hidden, please login to view installed on your TouchPad. Our will give you a step-by-step of how to install Internalz (or any other homebrew app, for that matter).
LG-Ernie
Hello, I have a LG55E7N and I wonder how I can delete a channelgroup
I made by mistake several groups, like 1,2,3,4,5, etc
And I like to delete them
I have been trying now for several days , but no luck
Any help would be very appreciated
