I finally received my Touchpad in the mail after the 6-8 weeks I had to wait. It's charging now. I set it ll up and downloaded some apps. Wish there were more ofcourse...
Since there is no gesture area, one thing I hate is the no "Back" gesture. How to you go back in an app?
I tried skype, works pretty well.
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By ajmboy
    • By Alex
    • By pivotCE
      webOS friend and LuneOS project aficionado, , recently embarked on an unlocking adventure.  His HP TouchPad 4G gave up the ghost and passed away quietly.  So he did what anyone would do and got a new one!  That’s what you’d do if your TouchPad died too, right?
      His TouchPad was special though.  In fact, you probably read his article right here on pivotCE about with an unlocked Sierra 7710 card in it.
      Why not just crack open the new one and pop in the 7710 and throw away that crappy “3.5G” Ericcson card?  Well, the TouchPad pretty much breaks when you open it.  The little clips that keep the back connected weren’t designed to be opened once engaged.
      After Herrie contacted, paid for, and was reimbursed by several unlocking services over the course of about a month he finally stumbled upon which was able to get him an unlock code.  The catch?  It took 2 weeks but it only cost him about $10.50 USD.  Not bad!
      Need your TouchPad 4G unlocked?  Head over to www.unlockfusion.com and I’m certain they can help you.  Or crack yours open and pop in a Sierra 7710 (EU) or a Sierra 7700 (NA).
      #webOSforever
      Related posts:
