Hi, Does anyone know how to change the start up source on a
LG 55UJ635V L tv?
When i turn it on it starts at Live tv which i dont use so i have to keep changing it to my Sky box (HDMI) source. keep reading it should turn on at the last used source but it doesnt?
LG suggested change HDMI ports but that didnt work?
driving me mad, even reset the tv and its still doing it?
16 answers to this question
When you setup your tv don't say you have live channels. If you don't do this, it will not display the live tv any more.
You have to choose settopbox and then select the sky box.
  • Like 2
Think that did the trick mate? weeks ive been trying to sort that for weeks, even asked Lg they sent me a pointless email, doesnt even mention it in the manuals? Still hard to believe you cant change that setting ithout reseting the tv? Smart tv? mmh
I had live tv for some time but my provider had problems so I changed to a provider who used a settopbox.
First I had the same problem as you but I managed to solve it. I don't know for sure that I did reset the tv but I had to choose the settopbox from the connector menu. A bit like this old tutorial:
The problem was that after this part they ask for your provider and the type of settopbox and that last was a bit difficult to find.
But, when I got it all working, I can use my magic remote to change channels and when I push the live-tv button it wil bring me back to the settopbox input
Good luck,
Peter
When i reset it there i ignored the livetv+ setbox option, just chose set top box, no massive deal reseting it right enough it just took a few minutes, to be honest i wouldnt be surprised if when i come in from work tomorrow and turn it on it goes to live tv again, i see the option is still at the top when i press the connections button on the remote.
my provider is Sky, not much else in the UK.
That could be a translation problem. Mine is in Dutch so YMMV.
Does your set-top box have a symbol that it is connected to your TV (a small remote symbol)?
Do you have a magic remote? What happens if you press the direct-tv button (looks like a small tv)?
Its a Sky box mate, doesnt have a display on it.
I had a magic remote but didnt really use it as can control most things with the Sky remote so sold it.
the first time i set the tv up i had an android box, games console and the set top box going into a HDMI hub and the hub the only cable going into the back of the TV.
I removed the hub at the weekend there and put all three boxes directly into the TV as there is 3 HDMI ports, wonder if i take them out and put them back into the hub it will stop doing what its doing?
Ah, that is not what I meant. Does the 'set-top box' symbol in the 'connected device' menu has a symbol on it that it is configured?
Don't think that using a USB hub will help.
Probably not but cant think of anything else?
If somebody just played an X-box on their new tv most of the time it must be possible to change a setting so the tv starts on that source?
ridiculous if you cant?
I sent Lg another email, probably get the same reply.
Settings → All Settings → Programme → Programme Tuning and Settings → Programme List Update → Off
This issue happens because your TV is trying to search for updates within the TV's channel listings. This was something that was implemented with the latest software versions because the governing body who look after the channels wanted the TV to scan for updates at 4am in the morning. This means that your TV will switch to your Live TV for this update, and cause your TV to default to that input instead of the last input used as it thinks it was the last one. Turning this off will stop this process and hopefully keep your last input used on.
I FINALLY found a fix for this. Well, really a workaround, but it solved the problem for me. I went into parental settings and set a passcode lock on the live tv and component inputs. Now, my tv starts up perfectly on whatever HDMI input I last used.
OK, do you know how to do this if I already set up my TV and didn't do this?
On 1/29/2018 at 12:46 PM, maninblack2000 said:
I have went into the all devices menu and clicked on 'remove from launcher'  (live tv) turned set off on and it worked fine, whether it does tomorrow is another matter haha.
I can't find "all devices" on mine.
    • By woof
      I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
      LG’s Better Life for All vision encompasses every aspect of life, emphasizing sustainable living and raising educational standards for children in rural areas. In line with this commitment, LG offices around the world actively participate in local initiatives aimed at improving the lives of the people and communities they engage with daily.
      To commemorate World Cleanup Day (September 20) and International Coastal Cleanup Day (September 21), LG Singapore organized its first-ever beach cleanup event at East Coast Park in conjunction with local green social enterprise
      link hidden, please login to view.
      As part of the brand’s sustainability efforts, this initiative sought to highlight the importance of taking action against Singapore’s growing marine plastic pollution problem while promoting the 3Rs – Reduce, Reuse and Recycle – when dealing with used packaging.
      By combining the company’s eco-conscious innovations with a community-driven effort, LG Singapore hopes this initiative will help foster a culture of environmental consciousness within consumers.
      With the much-appreciated help of Green Nudge, over 100 LG Singapore employees collected 293 kilograms of trash – mainly plastic packaging, bottles and Styrofoam – from three sites across Singapore’s eastern coastline, which was then carefully processed for proper disposal.
      To foster camaraderie among employees, LG Singapore organized eager volunteers into teams and promised an award to the group that collected the most trash. The winning team, which collected a total of 104 kilograms of trash in just one hour, received a small token of appreciation from Gerald Chun, managing director of LG Singapore.
      The success of the beach cleanup highlights LG’s dedication to environmental stewardship and community involvement, with the revitalized beach serving as a powerful reminder of the impact collective action can have. LG Singapore looks forward to promoting sustainability in more exciting ways and inspiring others to join its mission to preserve nature.
      Moving on to another vibrant part of Asia, in the spirit of Life’s Good, LG Taiwan hosted an event in September to inject positive change into the local community. Since 2009, LG Taiwan has been deeply committed to improving the standards of education in the nation’s rural areas, working alongside third-party organizations and public welfare institutions to inspire warmth and hope. This long-standing dedication was recently demonstrated through a collaboration with the Feng Chia University School of Architecture.
      This involved LG Taiwan assisting Feng Chia University’s Book Hut Project to create an impactful after-school learning space for children living in the countryside. First, LG donated smart home appliances to meet their daily needs, with the local children taking an immediate liking to the LG TV’s advanced voice control features and its sheer size. LG also donated two washing machines that make everyday laundry easy and convenient, requiring only the press of the power and start buttons to operate.
      Under the leadership of Jeong Yeon-kwan, managing director of LG Taiwan, a team of 23 LG employees joined student volunteers from Feng Chia University in Hualien to transform a building into an inspirational learning environment with a new lick of paint and various decorations.
      In addition to getting hands-on in Hualien, LG Taiwan donated home appliances to the rural Nantou and Taitung regions to spread the power of education. Managing director Jeong showed teachers and children how each appliance works to ensure they received the full benefits. And to add a personal touch to their visit, LG volunteers prepared Korean snack packs for the children and student volunteers.
      To support the transformation of its local community, LG East Africa collaborated with Korea Food for the Hungry International (KFHI) to complete two local projects. These initiatives – in Kajiado County and Nairobi’s Huruma slums – were the winning entries of the 2024 LG Ambassador Challenge. Each received KES 1 million in funding to make an impact on local communities.
      As a part of the first initiative in Kajiado County, LG East Africa took part in transforming Intinyika Primary School. The school, which has 180 students, was equipped with essential infrastructure, including a solar power system, water storage facilities and computers. These upgrades address critical needs, such as electricity, water and educational resources, significantly improving the learning environment for local students. LG is hopeful that the new equipment will benefit and improve the lives of local students, with the new computers enabling them to learn more about digital technologies in a more comfortable learning environment.
      In Nairobi’s Huruma slums, LG East Africa provided aid to the Furaha Community Foundation to improve their physiotherapy center, which treats more than 30 children with disabilities. With the funds from the LG Ambassador Challenge, the center acquired essential equipment, including gym tools, to provide effective care and treatment.
      Now in its fourth year, the LG Ambassador Challenge is part of LG East Africa’s social responsibility initiatives. The program aims to recognize and support groups that actively address pressing challenges within their communities. The 2024 edition saw 53 applications, with the winning projects standing out for their potential to create lasting change. To ensure the sustainability of these projects, KFHI will continue to provide customized monitoring and support. This includes regular visits, communication and oversight to maximize the impact and facilitate meaningful change within the communities.
      LG will continue to arrange various activities around the globe to spread its Life’s Good brand promise. To learn more about LG’s local initiatives around the world, visit .
      Contributed by LG Singapore, LG Taiwan and LG Kenya
    • By starwoodtech
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
    • By Ramya Shyam
