Use Magic Remote with Windows 10 PC on HDMI?
I just routed an HDMI cable to my PC that is in a different room.  Now I'm thinking it would be great if I could use the remote on the PC.  Does such a thing exist?  I didn't find anything when searching.
4 answers to this question
On 2/4/2018 at 10:01 AM, nemilose said:
I do not think that you may use magic remote with PC, but you can use a phone app, such as Unified Remote.
well I use Unified Remote, but is there a plugin to use the Magic Remote as a Unified Remote mouse control?
It should be possible with Windows wireless screen sharing but mine is connected wired trough hdmi.
@kleajmp The LG Magic Remote can ONLY be paired with an LG smart TV with the internal BlueTooth adaptor inside it. It is usually a little WiFi/Bt Combo card about 2 inches square.
I have never heard of any "plugin" to use the LG Magic Remote for any other purpose.
    • By Venkata
      Hello Team,
    • By OliverRC
    • By David Daul
    • By RJ Fischer
    • By hollean
