Airtel tv app not able to load
By kp bose
Please take steps to include Airtel Xtream Play app in WebOS Content Store!
In India everyone is using Airtel network and Xtream Play as a bundle recharge offer with it!
LG TV is very good and technically advanced! For this mere reason of not having Airtel Xtream Play App, We Customers, need to switch over to other brands!
So, it is mandatory and timely, for LG to make Xtream Play available in WebOS TV, otherwise you have to loose your trusted Customers like us!
Please think twice and Consider!!!
By Muser
By Karthick Sri
We need Airtel Xtreme play app on web os natively, on content store it is an important ott just like prime video,
Reason: having this app originally in lg store helps in utilising hdr -10 and other advanced options as the native settop box has only normal HDR,
S0, developer please consider creating one.
By Fletcher
I have recently purchased an LG 43UH610T television. I am located in Bali, Indonesia. Everything seems to be working fine, but when I click on any of the options, such as LGTV, YouTube etc, it tells me I must first consent to the LG Smart TV user agreement. However, I then get a message saying "Unable to load user agreements - a server error has occurred ......"
Can you help?
Gadige Haris Chandra
I have LG OLED 55C7T TV bought in Dec,2017.
I have a problem. I'm unable to download AirtelTv app. what is the way ? May be this app is not supported by Webos of LG smart TV.
Any one tried this app before. Please help me. I called Cust. care but they are dragging the issue saying, that it was referred to their technical Dept. And will revert back. Pls do help
