TV turns on during night bug
By Gene680
It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing? It’s when I’m streaming on Sling.
By matesz
By DAJ
I have an LG tv 43UP77006LB.BEKFLJP. Just recently, having owned the tv for a couple of years, the tv has taken to switching itself on during the night, usually at about 2.00 am. The tv is connected to a TalkTalk box for recording purposes but that has never caused an issue before. It appears to coincide with connecting a DVD player using an HDMI cable to the tv, although it was only connected for a short time and is now disconnected, so it may be irrelevant.
It appears to be a common problem.
Thanks.
By will price
I’m turning on with remote and then it automatically turns blank after a few seconds
comes on with lg logo but after a few seconds turns blank and will not do anything or display anything
- 4 replies
- 1,119 views
Can't play/pause in browser after update webOS nano79sna, version 5.2.1-2521 jhericulr-jardine
By Esteban Díaz,
- 7 replies
- 4,462 views
- 5 replies
- 6,101 views
- 2 answers
- 7,773 views
