Why is the satellite  tv guide so slow to start, to populate once started and to navigate? This is so important, if sky can get this to work fast why can't you?
Can you not make the guide cache itself to speed things up if it's opened in the same hour?
Navigating up and down 5 pages of channels is so slow. So is navigating left to right by time of day.
Please fix
    • By Peter_T
    • By OhmorrowSouthWales
    • By Mandx
    • By Michael Hirons
    • By Tony Levy
