Startup LG TV full screen in WebOS for Digital Signage
I am using a LG 65-inch 4K Ultra HD 120Hz LED Smart TV with WebOS 3.0 (65UH6030) as a digital display.
Every day I have to manually turn on the TV, go to the WebOS app, open a URL (http://www.tapnarts.com/signage) and then expand WebOS into full screen and move the cursor over to the top right hand of the screen to try and hide it.
Is there a way in which I could schedule the TV to automatically turn on everyday and open WebOS in full screen mode opening a URL (http://www.tapnarts.com/signage) and hiding the cursor? I would also like it to turn off at a specific time so it is not running 24/7.
  • 2 weeks later...
Currently no there is not.
  • 1 year later...
I did find a LG YouTube video that shows how to set up a TV that will not be used for live TV services, the link below should start at the point with the relevant setting:
The feature would probably be dependant on which model is is available on, but there is nothing to loose just by having a look.
    • By DWINKS49
    • By Batman
