hey,
I am developing a web App and i am trying to display the current bitrate/speed of the streaming and how many chunks was download.
 the LG documents i have found only a reference to the mediaPlayInfo object who has a bitrateInstane and a bitrateTarget fields, and both hold constant values that
 does not change throughout the streaming proccess
anyone knows of a way to get the current bitrate/speed from the LG player?
thanks
9 hours ago, omer shimran said:
hey,
thanks
Probably better to ask this question over at the official LG Developer website:
    • By Dogz
      Re. LG C2 TV, WebOS ver. 03.30.16
      In the TV guide if you hover over a program selection (or it's (i) symbol) with the pointer the program's info dialog pops up.
      The problem I have is that after 5 to 10 seconds, while the program selection remains, the info dialog reverts to the currently playing program. This is a real pain as I for one can't read all of the program info in that time.
      If this is intentional is there somewhere I can configure the info display time or is this (as i suspect) a bug?
    • By Som Parkash Jangra
      Please provide airtel x stream app on webos platform whereas this app is available in Google Play Store.
    • By GiovanniG
      Hi! Thank you for your kind help
      I'm looking for a way to show an IP camera to LG TV, I've updated it to the latest version (WebOS).
      I really hope it is possible without buying an external HDMI box, there is any way to obtain that or install apps from USB? Thank you a lot!
    • By Alex
      All LG TVs with webOS 4.0 or higher (2018 - current models)
      Sign up for Paramount+ on your LG TV
      You can sign up for Paramount+ on your LG TV with these simple steps:
      Launch the Paramount+ app, and select "Sign Up".  You'll see an access code displayed on your TV screen.  Visit paramountplus.com/lg on your computer or mobile web browser, and enter your access code, then click "Activate". Choose a subscription plan, then click "Continue."  You will be prompted to create a Paramount+ account, or if you already have one, sign in. Enter your payment information, then click "Start Paramount+."  You'll see a confirmation screen, and you can return to your TV to stream Paramount+. Stream Paramount+ on your LG TV (existing subscribers)
      Once you have added the Paramount+ app, there are two ways to sign in:
      On your TV Go to Settings > Sign In.
      Select On my TV. Enter the email address and password you used when subscribing to Paramount+ and select Sign In. That’s it!
      On paramountplus.com
      Go to Settings > Sign In.  Select On paramountplus.com.
      You’ll be presented with a website and a code. Make a note of this code—you’ll need it for the next step.
      Visit paramountplus.com/lg on your computer or mobile device, enter your activation code, and select "Activate". If you’re not signed in to Paramount+ on your computer, you’ll need to do so here.
      Your screen will refresh, and you can start streaming on your LG TV.
      Read more here:
