By Flavio_S
By kongo09
I use an IPTV app to watch TV and would like it to start automatically when the TV is switched on. The TV insists switching on with the not working cable TV tuner.
This is WebOS 5.5
By Extra Celestial
Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
By 152bobby
I have been trying to get my Google Home and Nest Audio Speakers to turn my LG OLED65C24LA TV on and off. I have linked ThinQ to Google Home but it still wouldn't work. So plan B was to get a Chromecast to do this one simple voice activated request....I have no intentions of using Chromecast for anything else!
So this actually does work, however, when asking it to turn the TV on, it defaults to the home page of Chromecast TV, I want it to just open to my normal TV system, which is Sky Q. Ideally, I would like to disconnect the Chromecast and just get Google Home and ThinQ to do this !!
I have checked every setting and trawled the internet for a solution. I've posted on the AV Forum in the UK and the Google Forum and I'm waiting on a call back from LG Support UK.
I expected this to be a VERY simple task !!
Can anyone help with this ?
