By Will M
By David Joseph
By Владимир Морозов
By andystaffs
Just bought a new LG 43UT91006LA TV .
After one week we're getting a "short of memory " screen warning before TV shuts off and restarts . I've not loaded any apps but I've managed now to delete one . I've checked that the apps are updated . I'm thinking that I can rid myself if the games but not sure how to do this ..I'm a bit baffled that a one week old TV can't cope with it's pre- installed apps ?!
By Lee Magee
Verwijderen aub
I have a 49UJ634V television. When I install the YouTube app from the content store the app starts to reboot with the pop-up “out of memory app will restart” but this is then with everything . Live-tv, guide, etc
this is a app problem beacause when I delete the app everything else works fine again.
