8 hours ago, Afshinrapka said:
Hello Please help friends, you in my country, unfortunately webos service does not work. How can i get into youtobe, thanks
Currently to my knowledge there is no VPN app for webOS.  If you mode/router supports VPN you could direct the service through that instead.
  • Thanks 1
    • By anna groove
    • By Sqwazy
    • By Gabriel Śmiech
    • By forum1
      My LG 49UB850V LED TV  browser is too old. The most of the pages not work any more. How to easy update just one simple browser app? For example, often browser show error during open new page. It show certificate expire problem and page not load at all.
      This mean LG sell product without update at least browser certificate and now we are stuck and can not even load one page from WWW.
      Shame on you LG. I will not buy any more from you.  How dificolt is to release new update to update OS certificates? Microsoft Windows did this, android did also for old phones, etc... Really, can not undestend this asian people from Korea.
    • By HarryX
      I have an existing account with a VPN provider,
      link hidden, please login to view using the Eddie API on Arch Linux systems. See  . My preference is to install that on the new LG TV I bought recently. Is that possible? If so, how?
