Have you ever wanted (or needed) to create your own app for webOS?
I did.
My aim was to create custom apps to launch websites or local html/css/javascript files.  Read on for…
What I did:
Since I knew nothing about Mojo or Enyo, I went looking for a simple template app that I could customize as required using nothing but a text editor and Jason Robitaille’s IpkPackager. But if such a template exists, I couldn’t find it. So I created one. You can get it over at
Go explore the template app!
The template app contains a set of detailed instructions and the files are commented to make them easy to understand.
The app also contains instructions for launching local files rather than a website. The idea is to make it as simple as possible to create apps for webOS using regular html, css, and javascript. If the learning curve isn’t as steep, perhaps more users will be able to help themselves.
If you make improvements to the template, please fork the repository and contribute!
If you have questions or comments, visit the story thread over at .
Related posts:
    • By Pranay Mokida
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
    • By Nihar Ranjan Dash
      The international content on JioCinema and Hotstar apps are not playing. No issues with Indian content in Hindi or other regional languages. But English, Korean, and Japanese content are not playing. Specifically, I want to play Disney content on Hotstar and HBO content on JioCinema App.
      I tried resetting all configurations and reinstalling the applications and re-logging into the apps. Still, the issue persists. I tried switching off the TV and tried pressing the power button for complete discharge and rebooting my router, but the same issue persists.
      **I found a workaround though, changing the wifi network or using a mobile hotspot on TV and then all content plays well even if I revert to my primary Airtel wifi, It still plays. but the next day the same issue continues.
      It's an overhead to switch the wifi every time I want to watch Hollywood titles. Certainly, it's not the experience I want with a TV of a hefty price tag. No other devices (Mac, ios, android, windows, Android TV) have this problem. Also, it's not the wifi issue, as I can watch the same titles on other devices. The LG TV also doesn't have the capability to remember a few WiFi networks to ease this workaround of switching networks.
      Alas, Nobody informed me about this issue earlier while making the purchase. Now such pricey TVs shouldn't have these issues at all. Kindly let me know If there is a permanent fix for this issue.
