By Horniak
By CJ Catalano
By JRay
By bos2prov
- 1 answer
- 709 views
- 1 reply
- 2,120 views
- 8 replies
- 35,762 views
- 2,344 views
emmanuelbeziat
Hi everyone,
It seems that the Window command "Read on device" don't work properly with My LG UH661V.
The problem:
Minor issues:
Other points:
Any thoughts on this?
Thanks !
