amazon prime app for LG smart v
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
By Annie Yazbeck
I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
Shrinivas
Is amazon prime tv available for 47LB5820. If not how to stream from iPad or laptop.
