By hollean
By Fredrik Andersson
By John Nguyen
By janisad
I have an LG 32LJ610V TV.
By Evgeny Dubnov
I intend to buy LG TV 43UK6300Y.
So question: if this TV require the Bluetooth headphones which must support LG sound sync (wireless) function.
If yes, could you send the list of acceptable Bluetooth headphones.
Thank you,
Evgeny
- 2 answers
- 680 views
Using ARC sound bar and bluetooth headphones at same time C9 OLED TV
By Nigelrw,
- soundbar
- headphones
- (and 2 more)
- 3 answers
- 5,595 views
- 2,557 views
- 0 replies
- 2,653 views
Eduardo Andrés Muñoz Castro
Hey everyone
Im trying to conecto to my 55UJ7500 with WebOS 3.5 a pair of bluetooth 4.1 heaphones. My idea is have them playing the tv audio at the same time to use with a friend.
Im able to connect both but only listen in one at the sane time.
I dont know if there is any confuguration to do this or some other alternative
Thanks =)
