how to change hdmi tv source using a learning remote
By OliverRC
By RJ Fischer
By hollean
By JamieG
Adam Harbour
unlike most remotes i dont seem to be able to toggle between hdmi sources by pressing a source button. On my LG OS tv i click the source button or magic mouse though the bottom source icons. Because if this i cant use a custom learning remote etc. Am i missing something - is there a setting i can change to make the source button toggle hdmi sources (and thus have a learning remote clone its IR code) or is this by design ?
3 answers to this question
