Youtube app of lg web os tv
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
network connection Pop-Up message; LAN disconnected/connected continuously pops up
By yeetmopedfoahn,
- 3,026 views
Hemant Ainapure
On lg web os tv, youtube can be accessed directly by the youtube app provided by the tv. Why are the 3 vertical dots which provide the pop up menu ( not interested, add to playlist, ... ) are not given for every video clip ?
Is there any trick or hack to make the pop up menu appear, and make a selection of desired option ?
