I have to say, YES I'm using TrueMotion and YES I'm lucky with that fact :-)
But "time after time" this setting is reverted to off. I have to set for live-TV, for Netflix, for Amazon-Prime over and over again...
Is there a solution to set every channel, every app to always on?!
TV is 55uj6309 with webOS 04.70.45
    • By Cody94549
      Key Specifications:
    • By Low Grade
      many thanks in advance😃
    • By Magsing
