apps for lg web os smart tv
19 hours ago, Vvsn Raju said:
Anybody can tell how to download apps for LG Web  os smart tv?
And also want to know configuration of magic remote.
Apps are downloaded via the LG Content Store, which is available from the ribbon menu.
Once you are in the store use the arrow buttons on the remote to highlight the round icon with four squares in it (this is the actual content store), once in you can select and install apps.
Cannot help you on the remote, I do not have one.
Magic Remote  setup/configuration:
Reset your LG > Advanced Settings > General
Your TV will reboot.
Have your magic remote ponted at tv for when reboot completes
You will be prompted to click on enter/ok (depress wheel on centre of remote)
Step by step instructions will follow to configure remote for peripheral devices (cable/media boxes, Home Theater, Blu Ray, etc). App content in LG Store
Enjoy!
    • By Will M
    • By Lesbo
    • By Pranay Mokida
    • By Rex G
    • By MNHL
