How do I remove a wired internet connection?
I set my oled65b7a tv to use a wired connection.  That worked.  Now I want to use wireless instead.  There doesn't seem to be a way to remove the wired connection.  Which is it actually using and how can I remove the wired connection information?
3 answers to this question
If you unplug the Ethernetcable from the back of the TV it will disconnect the LAN connection. Then you just set up the wireless connection and you're set. You're never going to get the same reliability and speed from wireless that you do with a wired connection, so unless you absolutely cannot have the wired connection your best bet is to leave it be.
    • By Mandx
    • By akhil7j
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By Chris Schults
      I live in netherlands so I have all in dutch on LG. But there are some big tiles on the screen (see image) Thuiskantoor Game Muziek etc.
      I do not use them and want to get rid of them. But I can not find anywhere in users guide How to do that. They appeared after last updat of WebOS.
      Greetings
      Chris
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
